Fallout 3 with no CD
37130 Views 20 Replies 10 Participants Last post by  AntiTalent
How do I play fallout 3 without having to have the CD in my comp everytime i wanna play i?
1 - 20 of 21 Posts
I could be mistaken but I believe you use the product key in the box and activate Windows Live.
Launch fallout3.exe directly.
make an ISO of the game, and mount it?
go on
Maybe you can use your CD key in Steam? I bought it from Steam, so, I wouldn't know about a hard copy. I just know you're able to input cd keys from some games and it'll load them into Steam making updates automatic, and cd's not required.
As I posted above, Fallout3 will launch without a CD if you just launch Fallout3.exe, and not the falloutlauncher.exe
You'll need the CD to use the launcher to change any of the main settings (resolution, AF, AA etc), but if you're happy with it, you can put the cd away no problem.
Might need to register for GFWL first, I don't know about that - did it when I installed.
I think the number of games you can register in steam is actually still quite limited right now, don't think it'll work with FO3
So fallout3.exe doesn't ask for a cd? That is awesome, I hate switching cds. Thanks for that knowledge. As for Steam, a retail Fallout 3 can't be registered on it, I tried.
No it won't.
PS: I don't have CD key with me atm
Yeah, you have to register it with GFWL and then use Fallout3.exe.
Please explain how.
I could send you a cracked .exe over AIM, or upload it to a site.
Or you can do the registering thing.
AIM is bartmasta
What's the point in telling me about registering if 5 other people told me and I still don't know how to do it.
thanks tho
Originally Posted by Bartmasta
AIM is bartmasta
thanks tho
Should probably sign on.
All you have to do is install the game. If you can run it when you put the disc in to play, you can also go find fallout3.exe and that will bypass the launcher, no disc needed.
sorry it's bartmastah
it won't work for me
try reinstalling it
that fixed it for me
You can register in-game. After you start the game go to the option that says LIVE and if you don't have an account you can register one through there. Fallout3.exe works fine without the cd for me, I just changed my shortcut to point to that instead of the launcher.
After I press LIVE nothing happens, I only see the background image change each 10 secs
try reinstalling it
didn't work
_______
My brother has the case with him atm so I don't have the CD key right now but I will tomorrow.
1 - 20 of 21 Posts
