1 - 7 of 7 Posts
I have a little small hole at the bottom of my case. I was thinking of using that whole to put in a 144mm fan. But my question is would that help lower my temp on the mb or raise them? I know that the wrong placement of fans can be deadly which is why I'm asking. <br />
<br />
A little later when I get home I'll take pics and show you better what I'm talking about.
Heat rises, so I don't think it would make a difference.<br />
<br />
If you are going to do it, I'd probably make it blow in.
<tr>
<div>
Originally Posted by <strong>Murlocke</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1388617#post1388617" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Heat rises, so I don't think it would make a difference.</div>
</td>
</tr>
</table>
</div>Cry! Thank you for the fast reply though.
No need for a bottom fan. And a 144mm fan would be overkill.<br />
<br />
Edit : If i were you i would try and see it myself...
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>3xtr3m3</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1388624#post1388624" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">No need for a bottom fan. And a 144mm fan would be overkill.</div>
</td>
</tr>
</table>
</div>Well, I have one and no clue where to put it... Thought it might help but it looks like I'll be taking it back. Store brought so no RMA issues.
<tr>
<div>
</div>
<div style="font-style:italic">Edit : If i were you i would try and see it myself...</div>
</td>
</tr>
</table>
</div><img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
I have 2 80MM fans in my case.Both are Vantec Tornados (5500rpm).But besides that to the point.I have one on front blowing on the harddrives.Keeps them all around 75-80 degrees.<br />
And I have one on the back blowing out.My CPU temp is around 106 Idle System temp stays around 91.<br />
If I didn't have these fans,I would be much warmer.I have tried it to see what difference it made.
1 - 7 of 7 Posts
