1 - 4 of 4 Posts
Hi, I`d like to know what fan configuration should I use with my 4 case fans. Right now I have 1 intake fan on the side of the case, 1 exhaust fan on the top, one exhaust fan on the back and one exhaust expansion slot fan which in under VGA card.
Rear exhaust is 80mm and 35cfm, rear exhaust expansion slot fan has 16cfm, top exhaust is 80mm(unknown cfm) and side intake is 80mm(also unknown cfm).
My temps are: Idle GPU 38, amb. 34, MOBO 29, CPU 37
load GPU 60, amb. 44, MOBO 32, CPU 57
i would strongly suggest you do the following;
install a more powerful fan on the side inlet provided you dont have a fan on the front of the casing. The fan should be at least 100 cfm fan considering all the other fans that you have.
install another fan of 90 cfm in the rear exhaust slot closest to the psu...i am guessing you can achieve a 10°C temp drop using this method...unfortunately my FAQ aint out yet otherwise i will direct you to it for better information
and try to find out what the other fan cfms are..
1 - 4 of 4 Posts
