1 - 6 of 6 Posts
15 Year Club
OK, so my case has a few fans. They're the MASSCOOL fans that you can get 10 of at newegg for $10. They are great and move a lot of air, but two of them are in places that make noise because of airflow: Front and side.
Basically, I put these two fans in my spare 3pin mobo connectors, and now I need to know how to regulate them via Windows software. Speedfan didn't work. Help?
I was just about to recommend speedfan, I am not aware of any other software available that can do that. sorry.
Put rubber grommets between the fans and the case.
I use Vantec controllers NXP-205. Allow you to make it quiet when you are low use, and figure out best speeds for best cooling.
SOftware, outside of speedfan, got me
ive installed fanspeed but under speed there aint nothing listed as i want to change the speed of my fan any ideas how comes there isnt anything in the speed box when u goto configure?
Im not exactly sure what you're talking about. Can you take a screenshot please?
1 - 6 of 6 Posts
