So I just got a couple Scythe S-Flexes and realized I probably need a fan controller. I am looking at this Rheobus one so far http://www.newegg.com/Product/Produc...-808-_-Product
But my only concern is I have a couple of Articooling PWM 120mms doing exhaust, I cant find anywhere if these controllers will work with PWM fans. Does anyone know or can anyone suggest to me a controller (that wont break the bank) that will work with PWM? If I'm gona have to spend more for a fancier controller, I was thinking about getting some yate loon high speeds and ditching the articoolers. Am I correct in assuming that, even if I get the high speeds the fan controller will allow me to run them at a lower speed when I need them to be quiet? Thank you!
