Just realized I accidentally posted this in Water Cooling section.. don't think that is as appropriate as here...
Basically what I'm looking to do is replace all the fans on my wc radiators.
Noise isn't a HUGE issue to me (within reason, but I don't need silent), but regardless, I was thinking of getting SY1225SL12SH (4 per radiator, push-pull setups) and a fan controller for them. I'm not too familiar with fan controllers, and since I can't really find any in stores locally to check them out in my hand in person I'm going to need some advice, please.
I figure if I am using a controller, I want to get fans that are powerful, if even a bit noisy, because I can always dial them down for normal use and then, using the controller, step them up if I am benchmarking or doing something very intensive.
I have 2 x 120.2 radiators in the case, and I'm thinking of doing a push-pull on both of them. Any advice is greatly appreciated, thanks!
