Hey all,
Just a few quick questions on water cooling. I'm sorry if there's another post on these, but I can't check because search is disabled for maintenance.
1. Which direction is best for the fans to point? Should they be pushing air onto the radiator, or pulling air off of the radiator?
2. I've seen people mount Black Ice radiators onto the back of their cases, parallel to the back panel, and mounted on the spot where the internal (typically 120mm) fans are mounted. It was like mounted like this:
[rad]>[fans]>[something on one of the fans that looked like the fan, but was just a frame]>[back panel]
Well, for the life of me, I can't seem to find any of the examples I saw, so I ask: how is that done?
Thanks very much to any answerers,
~S
~S
