I cant tell you which is best, that will have to be someone else.But to paint the fan blades, just remove the clip that it is holding it in (normally under the brand sticker, and maybe a little cap) make sure you mask the inside so you get no paint in there. Also make sure you use light coats and wet sand. I did fan blades on my mods and they came out good.
