I am in the process of setting up a single WC loop for the my Graphics card and I was going to get this
Pump & Fan Speed Controller but I also want to be able to monitor the coolant flow and I was going to get this
Coolant Flow Meter But it gets hooked up to a Fan header on the Mobo. I have tried searching around, I even called Koolance up to see if maybe they had another way to hook up the flow meter, but that would mean getting TMS-200 Software
Thermal Interface Controller at a cost of $100.00 and I do not want to spend that much, besides it would be a waste for just hooking a flow meter, I still have to get the pump & a 240 Rad + Fans. Oh and I trying to say away from software based monitoring.
I am planning on getting the Koolance PMP-450S and the Bits-power 5.25 bay Res and primochill tubing. And my only option for a Block is from Danger Den Maze5 with the 1600/2600 mounting kit, as they told me after contacting them. As there is no WC Block for the XFX version of the ATI 5770, so I have to use the Maze5 with added heat sinks that I already bought.
So is there a 5.25 bay Controller that will handle Fan / Pump Speed control as well as Flow meter Monitoring, that I don't know of ? Or can't find.
I am upgrading my current rig and will be giving it to my Daughters. I am in the process of building, well more like getting (slowly mind you) all that I need to build my new rig.
Edit: Can I hook up Coolant Flow Meter & Adapter Board to the Controller that I linked above.
Any Ideas or tips are welcome.
Thanks
Dre
