1 - 2 of 2 Posts
So I have these two PWM fan controller heads on my P67 Deluxe motherboard. One is the CPU_Fan controller, then I have another CHA_Fan1 controller.
225
Now I can plug in a regular 3 pin Gentle Typhoon fan into the CHA_FAN1 and be able to controller through the Asus Xpert Fan controller (notice how both headers are 4 pins). But I can not plug in a regular 3 pin fan into the CPU_FAN and be able to control it. It will just run at full speed.
Is there a way to controller a 3 pin fan with the CPU_FAN header with some kind of adapter? What if I put the 3 pin fan into a 4 pin connector and just move the 3rd wire to the 4th spot so it is hooked up to the CPU FAN PWM?
1 - 2 of 2 Posts
