Is it beneficial to put the fan inside the case where the fan will be blowing air up(basically, air will be suctioned from the inside of the case then goes up and out the case) and through the rad or fan mounted outside the case where the air moves downward(outside air will be suctioned then goes down and inside the case) and through the rad?
I just thought that if hot air rises then technically you would be heating up the rad with the first choice, but the second choice would be problematic since the warm/hot air can't exhaust.
BTW, I have an XSPC RX360 and RX120 rad with 4 Delta afb rev. c fans.
thanks in advance
thanks in advance
