What do you mean by pegs?
Like the rubber screws?
If so, it's up to you. I like good old fashioned screws.
Originally Posted by Tator Tot ![]() They are alright, if you want something that holds tight, and cuts down on vibration, look at the Lian-Li Anti-Vibration Screw Set They are expensive, but they work very well, and hold the fans better than those rubber screws do. |
Originally Posted by Griffin ![]() what do you think of these ? http://www.acousticpc.com/acoustipro...an_mounts.html |
