Hello guys,
I have an Azza Solano 1000. I know its not the best case but for 50 bucks hey i figure its good enough for my first build.
I want to get some fan filters for the side fan. It states online that it is a 230 mm fan, however when i measured the internal diameter of the fan it was actually only 190 mm. Should I be looking for a 200 mm fan filter?
For the front two intakes are 140 mm so I will get those filters easily.
Are there any recommendations on fan filters? The one on the side is going to be a pain so I would like to attach it just with heavy duty paper clips for easy cleaning.
Thank you for the help guys.
