Fan Speed management
518 Views 1 Reply 2 Participants Last post by  TehStone
Good day lads!
So currently I'm using RivaTuner v2.24 for my Fan management. And I have schedule for my GPU like this:
If temperature is 1-70 degree Celsius = Fan Speed 40%.
If temperature is 70-90 = Fan Speed 75%.
So what I want to do is:
If temperature is 70 or higher activate Fan Speed 75% AND use this speed till temp will be 65 C. Then again activate 40% and use it till temo will get higher 70 again.
Is it possible to manage like this? Because now I'm having annoying thing. Cooler is quiet, then when temp is higher 70 it's getting louder and cool my gpu to 69 degree then it's getting quieter for a minute till the temp rise and round robin once again.
1 - 2 of 2 Posts
you can create an overlap in the temps so it will run longer on one setting, like for instance 1-70c = fan speed 50%, 65-100c = fan speed 75%. You'll just have to tweak the overlaps or the schedule to get an optimal setting.
Some games will cause heating faster or create more sustained heat so test with a variety of programs. I tend to favor a 3 or 4 tiered fan schedule if I've got the time. 40% fans, 60% fans, 75% fans, 100% fans (<stopgap for xtra high temsp).
1 - 2 of 2 Posts
