Originally Posted by
cRaZyEddie187;13006646
NZXT makes a 200mm that screws in with only two screws but it is still very secure. It spins at 1300rpm so it is on the noisier side but flows an incredible amount of air
http://www.newegg.com/Product/Product.aspx?Item=N82E16835146003
Ignore the bad reviews..mine has been running flawlessly for 6 months
I asked this in ATCS840 topic but got no avail responses. Are those fans good? Can those fans fit all three spots in the ATCS840 230mm holes? I'm thinking of grabbing 3 so I can replace the stock 230MM fans that come with the ATCS840 and running them at 7 or 5v depending on their performance.
I'm thinking of getting some Scythe Gentle AP-14s for the bottom intake and exhaust for this case, however how well is it verses Noctua NF-S12B FLX? or even are there any "better" fans for this case?
Also I would like to add 2 fans on the HD mount that the ATCS840 provides, however..again I do not know which fans are well suited for these applications. (I'm looking for the best noise/performance fans, something not too loud but not too silent that it sucks at cooling)
I have also asked if one should disable the top front 230MM fan as it draws out air prematurely, some say to leave it on, some say to undervolt it, others say to disable it completely. I'm not sure which I should do.
Sort of OT: What is the best way to mod the MB tray on this case, as I would like to hide most if not all cables and route them behind the tray.
Thanks for all the help OC community
- Sashi
