Originally Posted by Darren9
Seems unlikely you'd get 4 bad ones in a bunch of 8. Have you got all 8 daisy chained of 1 molex? Maybe a bad connection on one of the passthroughs? I'd try each one seperately.
Yes, I agree with him, try what he said. A few may be DOA. Although it doesn't seem likely maybe your PSU doesn't have enough power, I'm not sure how much wattage it can sustain continually, many companies put peak output on, and I haven't really heard much about InWin. If your PSU is old it may also be deteriorating producing less power. Try what Darren9 said first before worrying about DOA and PSU problems.
Originally Posted by tryagainplss
I don't mean to hijack the OP's thread, but does daisy chaining mean using the female molex of the first fan (which is connected to the PSU) to connect the other fans?
Yes I believe so, or whatever the fan connectors 3 pin to molex is then continuing using same pathway to PSU
