Fans for a Megahalem Push/Pull System?
996 Views 11 Replies 9 Participants Last post by  Shadowclock
Looking for some fans with decent/long wire length for my Megahalem Push/Pull system. Thanks!
1 - 12 of 12 Posts
I'm using a couple scythe slipstreams 110CFM and they work pretty good. Wire length isn't bad either.
I'm using the slipstream 40cfm / 800 rpm ones, push/pull, and still get great temps
For push/pull, I go for Scythe S-Flex F or G, Noiseblockers, Gentle Typhoons, or Yate Loons.
Scythe Ultra Kaze 300 with a fan control.
I don't suppose there are some good quality fans with blue or red LED's out there?
ULTRA KAZES with KazeQ controller
@poster above:
Coolermaster R4's are rated @90CFM, I have 6 of them in my Cosmos S and they are VERY good
I'm pretty sure they come in Red/Blue/Green
the ultra kaze seems like an overkill and a bit thick :S I am liking the Scythe S-Flex G though
Originally Posted by rastablast
@poster above:
Yes they do come in red, green and blue, and standard non-led black. Those are not good fans for a CPU cooler though. I have 6 of them as well that were in my HAF932. They make reat case afns thoguh. Also the Ultra Kaze 3000 is not a good fan because it undervotls terribly. I had 2 of those on my TRUE120 and one of them makes the ever so common whining noise when I drop the RPM's. Its well known that those are not the greatest 120x38mm fans, but for the price they arent horrible.
I would recommend some 120 x 38mm Panaflo's and add a fan controller to them. I am got rid of my Ultra Kaze 3k and the Panaflo's have been much better. Also, you can egt some 3-pin extensions for your fans for like 99 cents, or 2 bucks if you want them sleeved at just about any PC shop.
San Ace H1011's, Scythes have nothing against the San Aces.
Forgot about this one. Another great fan though.
THIS
THIS
and THIS...
Oh yea and also, my guide (1st link in sig)
1 - 12 of 12 Posts
