Hi all. It seems this is something a lot of people have trouble with, so I will support it here.
First, if you are able to get into a xWindows enviorment, you're better off than 90% of people, and this will be easy.
First, download Envy:
http://albertomilone.com/ubuntu/nvid...buntu8_all.deb
then run it. It will install the program Envy. Once it is done, go to Applications > System Tools > Envy
It will prompt you for your root password, enter it.
Click Install nVidia Drivers
When it asks you if it should configure the xorg.conf file, say yes. reboot.
The nVidia logo should show up when you log back into xWindows.
If you are one of the lucky people to break your install trying to get this to work, don't worry, I got you covered!
at a shell, type:
Go through the configuration, but DO NOT select nv or nvidia for the graphics, instead select VESA. Once you are done there, type "startx" to start xWindows and proceed with the steps I gave above to install Envy.
Questions? Comments?
wget http://albertomilone.com/ubuntu/nvidia/scripts/envy_0.9.7-0ubuntu8_all.deb
at a shell, type:
sudo dpkg-reconfigure xserver-xorg
