yes
HAF 922 Black Steel + Plastic and Mesh Bezel ATX Mid Tower Chassis - Refurbished
[RC-922M-KKN1-GP]
Overview
Following the overwhelming success of the full tower HAF 932, Cooler Master extends the HAF (High Air Flow) line to a mid tower in the HAF 922. This beastly chassis comes with rugged looks, massive air flow, and Cooler Master's trademark intelligently designed interior. Building the mean, dream machine is now well within reach.
real image
Customer Ratings:
- No review yet -
Add Review
Original Price$109.99
You save$30.00
$79.99
Add to Wish List
left right
left right
Features
Superior Cooling Performance
Extreme cooling performance that supports up to seven cooling fans overall, including three 200x30 mm fans at minimum noise. The spacious interior can accommodate a radiator for liquid cooling system and high-end hardware.
User Friendly
* Provides extreme airflow, uncompromising cooling performance, and ruggedly strong protection.
* Accommodates demanding high-end components, including full length graphics cards.
* CPU cooler retaining hole designed for quick CPU cooler installation.
* LED ON/OFF switch for front 200 x 30 mm fan.
* Patented button design for easy maintenance of 5.25" drive devices.
* Bottom fan can be set facing up or down to increase airflow throughout the case.
Cable Management System
Unbeatable cable management made for less clutter and system maintenance by allowing ample room behind the motherboard. The motherboard tray includes access openings for cables to rout in or out of the chassis, preventing damages to cables/components.
Specifications
Model
RC-922M-KKN1-GP
Available ColorBlack
MaterialSteel + Plastic and Mesh Bezel
Dimension (W / H / D)Main Unit: 253 x 502 x 563 mm / 10.0 x 19.7 x 22.2 inches
Box: 285 x 550 x 605 mm / 11.2 x 21.7 x 23.8 inches
Weight8.7 / 10.9 kg ; 19.2 / 24.0 lbs
M/B TypeATX / Micro-ATX
5.25" Drive Bay5 Exposed (one could convert to 3.5" drive bay)
3.5" Drive Bay5 Hidden, 1 Exposed (converted from one 5.25" drive bay)
I/O PanelUSB 2.0 x 2, MIC x 1, eSATA x 1, Audio x 1 (support HD / AC97 Audio)
Expansion Slots7 + 1
Cooling SystemFront: 200 mm fan x 1 Red LED on / off fan x 1 / 700 RPM / 19 dBA (can be swap for 120 / 140 mm fan x 1)
Top: 200 mm fan x 1 / 700 RPM / 19 dBA (can be swap to 120 mm fan x 2 )
Rear: 120 mm fan x 1 / 1200 RPM / 17 dBA
Bottom: 120 / 140 mm fan x 1 (optional)
Side: 200 mm fan x 1 (optional) (can be swap for 120 mm fan x 2)
For more information, please visit this products webpage.
MSRP: $109.99
[RC-922M-KKN1-GP]
Overview
real image
Customer Ratings:
- No review yet -
Add Review
You save$30.00
$79.99
Add to Wish List
left right
left right
Features
User Friendly
Specifications
Model
RC-922M-KKN1-GP
MSRP: $109.99
