Hello
So i've just done the finishing parts of my first water build in my pc and is about to do a test run, however im not sure its safe. So the thing is, due to the radiator size i had to plug in the 8 pin cpu power connectors to my motherboard before installing my radiator, which means they are plugged in now.
Does this turn on the motherboard/CPU or does the 24pin connector have to be set to turn on, would hate a leakage to ruin anything doing my test run.
btw its a asus p7p55d-e pro motherboard if that changes anything, thanks in advance.
