1 - 3 of 3 Posts
Hi, all. I’m looking to buy some new RAM for my new system. The system I’m building is a mATX gaming rig and as such I’m not sure what the best RAM for my motherboard is. My budget is around £300. I basically want to get the fastest RAM possible for my motherboard but I’m not sure if my motherboard will support the voltages needed for these RAM kits. If that is the case what is the fastest RAM I can get? My motherboard is the Asus P5B-VM Micro ATX<br />
<br />
<a href="http://www.asus.com/products4.aspx?l1=3&l2=11&l3=332&model=1312&modelmenu=1" target="_blank">http://www.asus.com/products4.aspx?l...12&modelmenu=1</a><br />
<br />
I was looking at these kits… what do u guys think?<br />
<br />
<a href="http://www.ocztechnology.com/products/memory/ocz_pc2_8000_titanium_alpha_vx2_dual_channel" target="_blank">http://www.ocztechnology.com/product...2_dual_channel</a><br />
<br />
<a href="http://www.corsairmemory.com/corsair/dominator.html" target="_blank">http://www.corsairmemory.com/corsair/dominator.html</a> - Corsair also do the 2GB DDR2 XMS2 Dominator PC2-6400C3 TwinX, which has lower timings.<br />
<br />
Any help would be appreciated
Welcome to the forum<br />
<br />
please fill out your system specs under user cp at the top of the page<br />
<br />
EDIT: I personally recommend G.Skill DDR2 ram. it is great and can hit ddr 1000.<br />
But i cant find it at the moment.
"I personally recommend G.Skill DDR2 ram. it is great and can hit ddr 1000.<br />
But i cant find it at the moment."<br />
<br />
"The Fury" that doesnt really answer my question does it? i need to know what is the fastest RAM i can get For that motherboard. i dont know if i am able to OC to 1000 with that motherboard.<br />
<br />
can anybody help me here?
1 - 3 of 3 Posts
