I dont really know what you are talking about but I would say Ububtu 8.04 is probably the slimest and fastest. Or you could go arch which is really fast.
Originally Posted by PCpwnz ![]() I dont really know what you are talking about but I would say Ububtu 8.04 is probably the slimest and fastest. Or you could go arch which is really fast. |
Originally Posted by kaivorth ![]() And I want to actually install linux to a flash drive. Not just a LiveCD. So how do I do this? |
Originally Posted by TheLaughingMan ![]() Regarding (x)buntu: -Ubuntu by default uses GNOME, which is considered a "heavyweight" desktop environment (DE), according to this comparison. -Xubuntu by default uses Xfce, which is considered a "middleweight" DE. It is essentially Ubuntu without Gnome. -CrunchBang Linux by default uses Openbox, which is considered to be "middleweight" window manager, not a DE. It is essentially Ubuntu without Gnome, or any DE for that matter. It seems to be regarded as a more lightweight & faster version of Ubuntu. I am pretty sure you can use Compiz Fusion on any of the three listed above, although I am not sure how well they work together & and how much tweaking is involved. Openbox seems to be the fastest of the three, but it is highly configurable, and thus, may require you to read a guide on how to use it properly. I would probably use Xfce, if you are new to all this. It should be fairly easy to use, and much faster than Gnome. Regarding a USB install, I would just follow these instructions. From what you said, I believe you want what is called a "Persistent" install. It essentially installs the whole distro, and a (persistent) partition for saving things on a single thumb drive. At the bottom of the guide, it talks about the size of the persistent partition. Depending on the size of your thumb drive, I would make the persistent partition as big as possible. Anybody...if any of this is wrong, please correct me. I try not to misinform. ![]() EDIT: It seems you already knew some of this... http://www.overclock.net/linux-unix/...ml#post5787769 Is it not working for you still? |
