1 - 5 of 5 Posts
I just thought we should end the questions about drivers by just posting what card you use and the drivers you think work best with them. If this thread works at all, I will start to compile which drivers are the most used for each card. I'll go first!<br><br>
eVGA 7800GT OC<br>
xtreme g 92.91
6800 Vanilla, unlocked to 16x6 with no overclock (325/350)<br />
<br />
Currently running 84.66 NGO's, but I also like the Z-Tweaked 87.25's and have good luck with them.<br />
<br />
Hopefully this thread goes well, I think it would be a huge advantage for the forums to have a driver database.
xtremeG 91.47's are very good drivers. Work superbly on my 7900GT
Hey, one more thought: It would help you out a ton if you end up going database if there was some kind of a set format, including info such as voltmods, BIOS flahses, and other overclock/benchmark info. Just a suggestion. <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Discussion Starter #5
alright, i'll make an excel spreadsheet when i get home today<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
1 - 5 of 5 Posts
