1 - 7 of 7 Posts
Rosewill Challenger $50
ASUS VX238H-W $180
ASRock 990FX Extreme3 $120
SAPPHIRE 100356OCL Radeon HD 7790 $155
FSP Group PT-650M $140
G.skill F3-12800CL8D-8GBXM $65
AMD FX-6300 FD6300WMHKBOX $130
Microsoft Windows 8 64-bit OEM $90
SAMSUNG 840 Pro Series MZ-7PD128BW $120
Phanteks PH-TC12DX $50
g400+qck+litey keyboard $55
ASUS DRW-24B1ST/BLK/B/AS - OEM $20
Originally Posted by trcx View Post
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
LIAN LI PC-A05FNB Black Aluminum ATX Mid Tower Computer Case
ASUS VS248H-P Black 24" HDMI LED Backlight Widescreen LCD Monitor
ASUS M5A97 LE R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
GIGABYTE GV-R785OC-2GD Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
AMD Gift coupon: Bioshock Inf. + Tomb Raider
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor FD6300WMHKBOX
Microsoft Windows 8 64-bit (Full Version) - OEM
OCZ Vertex 4 VTX4-25SAT3-128G 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
$1,104.90
please correct anything wrong with this build
in reality I will have the funds in 6 months, should I wait until then to create a better machine or buy part by part starting now?
If you were ready to build now it would be a decent build, but i wouldn't start buying parts with haswell around the corner along with the 8xxx series. I would defiantly wait till you have all your money.
Terrible at everything
Since it will take you a while to build up your funds, I would definitely hold off on getting the mobo, cpu, and gpu. Odds are you are going to see 1. Lower prices on those same parts in 6 months (motherboard, CPU and GPU) 2. There will be better equipment within your price range in 6 months. Personally, the prices of SSDs are dropping drastically. In 6 months they could be greatly reduced. RAM is gradually decreasing as well, 1866 RAM is getting closer to the 1600 price range. If you wait for parts and bargains on the pieces you want, SSD, RAM, Windows, power supply, case, and optical drive, you will be able to pay the lowest amount for all of your collective parts. With the new technology on the horizon, buying the CPU, mobo, and GPU is not a wise decision at this point.
All that summed up: Personally, I would hold off on purchasing until I had my funds together. I would watch the prices on those components least likely to be outdated in 6 months. If you wait 6 months you may save a couple hundred bucks on your current build and be able to purchase something really nice, like water cooling loops, or upgrade to better equipment for the same price.
Either way the build looks good so you would be happy with it IMHO.
EDIT: I might would opt for a slightly better motherboard as well, but that board is perfectly fine for what you want.
Biggest issue I have is why a build costing over $1000 in total has a cheap motherboard with no VRM cooling.... that should be changed, but it shouldn't cost much more if at all. You could probably offset it by making sure you get a DVD drive under $20 shipped (if it's over $20 shipped, that's just ridiculous).
But, in 6 months, things will probably change. My guess is Kaveri APU will be about out and if you read up on what that is and what HSA is (you can use the link in my sig), as that may totally change the game. There's also an FX CPU refresh and Intel Haswell coming.
Discussion Starter · #6 ·
did some changes and updated build, ty for tips
price jumped from original estimate so even though this goes against some suggestions
any more help with anything much appreciated.
i'm always updating the build on post 1
1 - 7 of 7 Posts
