1 - 13 of 13 Posts
Hi guys and gals,
Has anyone tried a feser one uv coolant? How is te performance compared to a distilled water/Pt nuke combination?
Originally Posted by Dar_T View Post
Distilled water is better but Feser One has some nice colours. Its cheaper and more practical to go with distilled water + silver.
Thanks..
Do you know how much better is the distilled water + silver compared to Feser ONe UV( I mean temp wise)?
And what if the price of the Feser One is only $7.38usd per liter/bottle, is it worth getting it over distilled plus silver?
I asked this because I like their colors..
Originally Posted by samster25 View Post
i am using it, and its great. it doesnt conduct, temps are low, my [email protected] idle temps are 23C, 39C load. on 1.376 vlots under load. the only problem is that its pricey. oh yeah if you are using used parts make sure you flushed them out.
Thanks!!.. WHat color do you have?
Also, how did you measure your temps using Realtemp/Coretemp or Speedfan?
I'm pretty sure Feser One is just distilled water plus some neon color. It may also have what I would call "Water wetter" which is an additive for engine coolant. Either way I see it, Feser One looks cooler and might cool about the same amount. However, I have not a clue what "+silver" means or how to do it.
Discussion Starter · #11 ·
Originally Posted by twitch101 View Post
the best color is from colored tubing but it can be expensive. if you want the cheap route some masterkleer and water, dye, and pt nuke works.
Yah, that is what I have ordered( Masterkleer, distilled water, PT nuke and Pentosin G11).
I heard from someone that mixing PT NUke with pentosin G11 creates some chemical reaction..Can anyone confirm this please?
Discussion Starter · #13 ·
im not sure on the pentosin but the only reason you would need the pentosin is if you had copper AND aluminum parts in your loop. if you are going all copper then you have no use for it.
Okay..Thanks for the info..
1 - 13 of 13 Posts
