Where the Apple Store, maybe I'll visit the next time I'm there maybe the sales people won't be as clingy as the ones in the US and here.
https://www.apple.com/tr/retail/zorlucenter/
The memory they will technically accept from their warehouses. Something about the modules and verified vendors. Silliness if you ask me. If you upgrade just keep the old memory for when you go in. Pop them back in and you will have no issues.
In that case if I upgrade only my RAM am I going to be fine?Originally Posted by KyleMart06
@iARDAs: You are fine to carry the computer or travel with it like GermanyChris said. The head will be parked when shutdown. That would be the biggest issue with moving it. Otherwise you are set.![]()
Yes certainly be careful but you will be ok. I would steer you to Crucial. We use them here at work and they have a good track record. Look up the model of the Mac Mini in their configuration tool and you should be golden.
I put Hyperx 1600 blues in my wife's (formally my) '11 13"..it gave it a geekbench boost but back in the real world it's just been dependable and lord knows it should have been for the amount I paid for it. That is the last time I'll be an early adopter of anythingOriginally Posted by iARDAs
Which RAM should I buy for a 2014 Mac Mini any tips?
And yeah I will just carry it and be sure that I shut it down before unplugging it. Hoping to be perfectly fine but will still be careful.
There's that, but it isn't a... what's it called... "Non-maskable key pattern?" It doesn't demand the OS's attention the way that ctrl + alt + delete does in windows.
Thank godOriginally Posted by The Hundred Gunner
And even then, it doesn't give you information about your processes. For that, you have to use Activity Monitor.
The base model of 2014 is a 1.4 Dual Core i5 though. I remember mine being 2.5 Dual Core i5.
Nope no TB accessories at all.
