1 - 2 of 2 Posts
I am wondering if this has an impact on the life of a GPU? I do this primarily to get better stability with overclocking.
Also, is there another program out there that will let me toggle this on and off without a reboot? I need to reboot my PC to toggle this off in MSI Afterburner. It works, but its inconvenient.
theoretically yes, but if the constant voltage is within spec for the chip, or at least within the range of the card's value range at stock, then most likely no or so little its unmeasurable
1 - 2 of 2 Posts
