Few upgrade questions...
210 Views 6 Replies 4 Participants Last post by  Lyshk0
1. If I have an average-quality E8400, could I get it to 4ghz with 1066mhz ram with my board?
2. I'm thinking of getting this SSD, will it significantly benefit me?
3. If I couldn't get my E8400 to 4ghz, could I get a Q9650 to that speed?
Thanks, I know these are kinda hard-to-answer questions, but any feedback will be appreciated.
1 - 7 of 7 Posts
You'll get your E8400 to that speed.
Yes a Q9650 can get to that speed, as well as a Q9550
Thats a nice SSD you picked, lil pricey though. Not worth it imo
Just get a better cooler. I'm sure the Zalman can do it, but there are better coolers out there.
Ok, I'll go with a Q9550 then. The reason I picked that particular SSD is because of the high read/write speeds. Most of the others are rated at 150/90.
Originally Posted by Juggalo23451
2I dont think it is worth do go ssd just yet. Wait till the prices drop
Well, I share the same sentiment somewhat, but my current HDD's are pretty slow for some reason, I crave epic fast load times for my frequently used programs
Your better off getting either
2 640gb hard drives
2 500gb hard drives
And Raid them. MUCH cheaper, MUCH more storage. That way, when SSD comes down in price, you won't be kicking yourself in the but
2 640gb hard drives
2 500gb hard drives
Isn't Nvidia's raid pretty bad?
And, would I get even better speeds if I striped 3 drives?
2 640gb hard drives
2 500gb hard drives
qft. this is what i did, and its pretty speedy. i am planning on a getting a pair of either 64gig or 128gig ssd's once the prices lower for another raid0 array to use as a system drive.
1 - 7 of 7 Posts
