Hi there. If you could answer these questions then that would be fantastic.
1. What is the best EK Supreme HF block to go with, as there are quite a few to choose from. If the differences are minimal then i'll go with the acetal and nickel I was looking at.
2. Are the threaded holes on components (for fittings) all the same size, making fittings universal.
3. When a fitting, a barb for example, states the measurement of 1/2, is that the size of the ID of the tubing it's compatible with?
4. Opinions on this radiator? - http://www.scan.co.uk/Products/XSPC-...mance-Radiator
It is to be used with the 120mm White LED Xigmateks.
5. I will look into blocks a little more, what are exactly the differences between the LT and the HF?How is this parts list that I have come up with...
6. What size barbs would you recommend for 1/2 ID 3/4 OD tubing?
7. How is this parts list that I have come up with...
Thanks!
That's all for now, will update if needed.
Thanks!
