1 - 6 of 6 Posts
Hey guys i want to share files with all the other pc's in my house hold.
As of now i can do it easily with my HTPC and Main desktop, both have Win7 and Im using the homegroup functionality
The other PC's i want to share with are using win xp and im looking for a way to share files over my network
any ideas fellas?
Usually lurking
I am using file sharing between XP/7 computers at my house. Just go into XP and join a Workgroup to whatever you called the one you made in 7. Then share whatever files you want over the network.
could you go into a little more detail
in vista - make sure u are on the same workgroup, go to the network and sharing center, and turn on public folder sharing.
easiest thing ever! now to share files drag files to the public folder, which is located on the left hand side when u open a folder under favorite links
in xp - read - http://windowsdevcenter.com/pub/a/wi...es-part-2.html
1 - 6 of 6 Posts
