for reference, this is what we have so far
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import java.io.*;
import java.net.*;
import java.util.*;
class VServListener extends Thread
ServerSocket listen;
UI current;
VServListener(UI current)
try
listen = new ServerSocket(10000);
this.current = current;
catch (Exception e)
e.printStackTrace();
public void run()
while (true)
try
new VobixServer(listen.accept(), current).start();
catch (Exception e)
class VobixServer extends Thread
Socket sock;
UI current;
VobixServer(Socket sock, UI current)
super("VobixServer");
try
this.sock = sock;
catch (Exception e)
public void run()
try
PrintWriter commOut = new PrintWriter(sock.getOutputStream(), true);
Scanner commIn = new Scanner(sock.getInputStream());
FileOutputStream fos = null;
BufferedOutputStream fileOut = null;
String comm = commIn.nextLine();
if (comm.equals("requestingfilelist"))
LocalProfile p = current.getCurrentProfile();
if (p != null)
for (int i = 0; i < p.getFileList().length; i++)
commOut.println(i + ". " + p.getFile(i).getName());
commOut.println("finished");
else
if (comm.equals("filerequested"))
int index = Integer.parseInt(commIn.nextLine());
File f = current.getCurrentProfile().getFile(index);
commOut.println(f.getName());
commOut.println(f.length());
byte[] bites = new byte[(int)f.length()];
FileInputStream fis = new FileInputStream(f);
BufferedInputStream fileIn = new BufferedInputStream(fis);
fileIn.read(bites, 0, bites.length);
OutputStream dataOut = sock.getOutputStream();
dataOut.write(bites, 0, bites.length);
dataOut.flush();
commOut.close();
commIn.close();
sock.close();
catch (Exception e)
class VobixClient
Socket sock;
VobixClient()
void getFile(RemoteProfile r, int index, String dest)
int bytesRead;
int current = 0;
try
sock = new Socket(r.getIP(), 10000);
String comm;
commOut.println("filerequested");
commOut.println(index + "");
String filename = commIn.nextLine();
int filesize = Integer.parseInt(commIn.nextLine());
byte[] bites = new byte[filesize];
InputStream dataIn = sock.getInputStream();
FileOutputStream fos = new FileOutputStream(dest + filename);
BufferedOutputStream fileOut = new BufferedOutputStream(fos);
bytesRead = dataIn.read(bites, 0, bites.length);
current = bytesRead;
do
bytesRead = dataIn.read(bites, current, (bites.length - current));
if (bytesRead >= 0)
current += bytesRead;
}while(bytesRead > -1);
fileOut.write(bites, 0, current);
fileOut.flush();
fileOut.close();
sock.close();
catch (Exception e)
String[] getFileList(RemoteProfile r)
ArrayList ar = new ArrayList();
String[] fileList = null;
try
String comm;
commOut.println("requestingfilelist");
while (!(comm = commIn.nextLine()).equals("finished"))
ar.add(comm);
commOut.close();
commIn.close();
sock.close();
catch (Exception e)
fileList = new String[ar.size()];
for (int i = 0; i < ar.size(); i++)
fileList[i] = (String)ar.get(i);
return fileList;
class KOptionPane extends JDialog implements ActionListener
JLabel name;
JLabel ip;
JTextField getname;
JTextField getip;
JButton confirm;
KOptionPane()
super(new JFrame(), true);
public void showInputDialog()
Container c = getContentPane();
name = new JLabel("Name of Profile");
ip = new JLabel("IP Address");
getname = new JTextField(15);
getip = new JTextField(15);
confirm = new JButton("Confirm");
confirm.addActionListener(this);
SpringLayout s = new SpringLayout();
c.setLayout(s);
c.add(name);
c.add(ip);
c.add(getname);
c.add(getip);
c.add(confirm);
s.putConstraint(SpringLayout.NORTH, name, 5, SpringLayout.NORTH, c);
s.putConstraint(SpringLayout.WEST, name, 5, SpringLayout.WEST, c);
s.putConstraint(SpringLayout.NORTH, ip, 5, SpringLayout.SOUTH, name);
s.putConstraint(SpringLayout.WEST, ip, 5, SpringLayout.WEST, c);
s.putConstraint(SpringLayout.NORTH, getname, 5, SpringLayout.NORTH, c);
s.putConstraint(SpringLayout.EAST, getname, 5, SpringLayout.EAST, c);
s.putConstraint(SpringLayout.NORTH, getip, 5, SpringLayout.SOUTH, name);
s.putConstraint(SpringLayout.EAST, getip, 5, SpringLayout.EAST, c);
s.putConstraint(SpringLayout.NORTH, confirm, 5, SpringLayout.SOUTH, getip);
s.putConstraint(SpringLayout.WEST, confirm, 110, SpringLayout.WEST, c);
setTitle("Remote Profile");
setSize(290, 120);
setLocationRelativeTo(null);
setVisible(true);
public void actionPerformed(ActionEvent evt)
dispose();
public String getName()
return getname.getText();
public String getIP()
return getip.getText();
class RemoteProfile
String name;
String ip;
RemoteProfile(String name, String ip)
this.name = name;
this.ip = ip;
return name;
return ip;
class LocalProfile
File[] fileList;
String name;
LocalProfile(String name)
this.name = name;
fileList = new File[0];
public void addFile(File f)
File[] temp = new File[fileList.length + 1];
for (int i = 0; i < fileList.length; i++)
temp[i] = fileList[i];
temp[fileList.length] = f;
fileList = temp;
return name;
public File[] getFileList()
return fileList;
public File getFile(int i)
return fileList[i];
class UI extends JFrame implements ActionListener
JTextArea hostFileList;
JTextArea remoteFileList;
JScrollPane hostScrollPane;
JScrollPane remoteScrollPane;
JButton addFile;
JButton requestFile;
JTextField indexField;
JLabel hostLabel;
JLabel remoteLabel;
JComboBox hostProfileChooser;
JComboBox remoteProfileChooser;
String[] remoteProfilesMnemonic;
String[] hostProfilesMnemonic;
LocalProfile[] hostProfiles;
RemoteProfile[] remoteProfiles;
VServListener listener;
VobixClient fileCatcher;
String destination;
UI()
//Initialize data components
hostProfiles = new LocalProfile[0];
hostProfilesMnemonic = new String[0];
remoteProfiles = new RemoteProfile[0];
remoteProfilesMnemonic = new String[0];
//Initialize GUI components
hostFileList = new JTextArea(15, 30);
remoteFileList = new JTextArea(15, 30);
hostScrollPane = new JScrollPane(hostFileList);
remoteScrollPane = new JScrollPane(remoteFileList);
addFile = new JButton("Add shareable file");
addFile.addActionListener(this);
requestFile = new JButton("Get file at index");
requestFile.addActionListener(this);
indexField = new JTextField(2);
initProfiles();
hostLabel = new JLabel("Local Profile");
remoteLabel = new JLabel("Remote Profile");
hostProfileChooser = new JComboBox(hostProfilesMnemonic);
hostProfileChooser.addActionListener(this);
remoteProfileChooser = new JComboBox(remoteProfilesMnemonic);
remoteProfileChooser.addActionListener(this);
//Initialize communication components
listener = new VServListener(this);
listener.start();
fileCatcher = new VobixClient();
//Create GUI layout
c.setLayout(s);
c.add(hostProfileChooser);
c.add(hostScrollPane);
c.add(remoteProfileChooser);
c.add(remoteScrollPane);
c.add(hostLabel);
c.add(remoteLabel);
c.add(addFile);
c.add(requestFile);
c.add(indexField);
s.putConstraint(SpringLayout.NORTH, hostProfileChooser, 5, SpringLayout.NORTH, c);
s.putConstraint(SpringLayout.WEST, hostProfileChooser, 15, SpringLayout.WEST, c);
s.putConstraint(SpringLayout.NORTH, hostScrollPane, 10, SpringLayout.SOUTH, hostProfileChooser);
s.putConstraint(SpringLayout.WEST, hostScrollPane, 15, SpringLayout.WEST, c);
s.putConstraint(SpringLayout.NORTH, remoteProfileChooser, 5, SpringLayout.NORTH, c);
s.putConstraint(SpringLayout.WEST, remoteProfileChooser, -342, SpringLayout.EAST, c);
s.putConstraint(SpringLayout.NORTH, remoteScrollPane, 10, SpringLayout.SOUTH, remoteProfileChooser);
s.putConstraint(SpringLayout.EAST, remoteScrollPane, -10, SpringLayout.EAST, c);
s.putConstraint(SpringLayout.NORTH, hostLabel, 10, SpringLayout.NORTH, c);
s.putConstraint(SpringLayout.WEST, hostLabel, 10, SpringLayout.EAST, hostProfileChooser);
s.putConstraint(SpringLayout.NORTH, remoteLabel, 10, SpringLayout.NORTH, c);
s.putConstraint(SpringLayout.WEST, remoteLabel, 10, SpringLayout.EAST, remoteProfileChooser);
s.putConstraint(SpringLayout.WEST, addFile, 105, SpringLayout.WEST, c);
s.putConstraint(SpringLayout.NORTH, addFile, 10, SpringLayout.SOUTH, hostScrollPane);
s.putConstraint(SpringLayout.NORTH, indexField, 10, SpringLayout.SOUTH, remoteScrollPane);
s.putConstraint(SpringLayout.EAST, indexField, -220, SpringLayout.EAST, c);
s.putConstraint(SpringLayout.NORTH, requestFile, 10, SpringLayout.SOUTH, remoteScrollPane);
s.putConstraint(SpringLayout.WEST, requestFile, 10, SpringLayout.EAST, indexField);
//Tells program to call saveProfiles upon closing
addWindowListener(new WindowAdapter()
public void windowClosing(WindowEvent evt)
try
saveProfiles();
catch (Exception e){e.printStackTrace();};
System.exit(0);
c.setBackground(Color.gray);
setTitle("Vobix File Transfer");
setSize(710, 370);
//setResizable(false);
setVisible(true);
//Loads profiles from INI
private void initProfiles()
hostProfilesMnemonic = addProfile(hostProfilesMnemonic, "New");
remoteProfilesMnemonic = addProfile(remoteProfilesMnemonic, "New");
try
Scanner ini = new Scanner(new File("Vobix.ini"));
destination = ini.nextLine();
while (ini.hasNextLine())
if (ini.nextLine().equals("l"))
LocalProfile p = new LocalProfile(ini.nextLine());
String file = "";
while (!(file = ini.nextLine()).equals("-p"))
if (new File(file).exists())
p.addFile(new File(file));
hostProfilesMnemonic = addProfile(hostProfilesMnemonic, p.getName());
hostProfiles = addProfile(hostProfiles, p);
else
RemoteProfile r = new RemoteProfile(ini.nextLine(), ini.nextLine());
ini.nextLine();
remoteProfilesMnemonic = addProfile(remoteProfilesMnemonic, r.getName());
remoteProfiles = addProfile(remoteProfiles, r);
catch (Exception e)
private String[] addProfile(String[] ar, String name)
String[] temp = new String[ar.length + 1];
for (int i = 0; i < ar.length; i++)
temp[i] = ar[i];
temp[ar.length] = name;
return temp;
private LocalProfile[] addProfile(LocalProfile[] ar, LocalProfile p)
LocalProfile[] temp = new LocalProfile[ar.length + 1];
temp[i] = ar[i];
temp[ar.length] = p;
return temp;
private RemoteProfile[] addProfile(RemoteProfile[] ar, RemoteProfile p)
RemoteProfile[] temp = new RemoteProfile[ar.length + 1];
temp[i] = ar[i];
return temp;
//Save all profile into to INI, will be called upon program exit
private void saveProfiles()
try
File save = new File("Vobix.ini");
FileWriter fw = new FileWriter(save);
fw.write(destination + "rn");
for (LocalProfile p : hostProfiles)
fw.write("lrn");
fw.write(p.getName() + "rn");
for (File f : p.getFileList())
fw.write(f.getPath() + "rn");
fw.write("-prn");
for (RemoteProfile r : remoteProfiles)
fw.write("rrn");
fw.write(r.getName() + "rn");
fw.write(r.getIP() + "rn");
fw.write("-prn");
fw.close();
catch (Exception e)
public LocalProfile getCurrentProfile()
return getLocalProfile((String)hostProfileChooser.getSelectedItem());
private LocalProfile getLocalProfile(String s)
if (p.getName().equals(s))
return p;
return null;
private RemoteProfile getRemoteProfile(String s)
if (r.getName().equals(s))
return r;
return null;
if (evt.getSource().equals(hostProfileChooser))
if (hostProfileChooser.getSelectedItem().equals("New"))
String name = JOptionPane.showInputDialog(this, "Name your new profile");
if (name.equals(""))
return;
hostProfiles = addProfile(hostProfiles, new LocalProfile(name));
hostProfileChooser.addItem(name);
else
LocalProfile p = getLocalProfile((String)hostProfileChooser.getSelectedItem());
hostFileList.setText("");
hostFileList.append(i + ". " + p.getFile(i).getName() + "n");
else
if (evt.getSource().equals(remoteProfileChooser))
if (remoteProfileChooser.getSelectedItem().equals("New"))
KOptionPane get = new KOptionPane();
get.showInputDialog();
remoteProfiles = addProfile(remoteProfiles, new RemoteProfile(get.getName(), get.getIP()));
remoteProfileChooser.addItem(get.getName());
else
RemoteProfile r = getRemoteProfile((String)remoteProfileChooser.getSelectedItem());
requestFileList(r);
else
if (evt.getSource().equals(addFile))
JFileChooser jfc = new JFileChooser();
jfc.showDialog(this, "Vobix");
p.addFile(jfc.getSelectedFile());
else
if (evt.getSource().equals(requestFile))
getRemoteFile(r, Integer.parseInt(indexField.getText()));
refreshFileLists();
private void getRemoteFile(RemoteProfile r, int index)
fileCatcher.getFile(r, index, destination);
private void requestFileList(RemoteProfile r)
remoteFileList.setText("");
for (String s : fileCatcher.getFileList(r))
remoteFileList.append(s + "rn");
private void refreshFileLists()
String sel = (String)hostProfileChooser.getSelectedItem();
if (!sel.equals("New"))
class main
public static void main(String[] args)
new UI();
