1 - 13 of 13 Posts
So my 6950 is not a reference card as it is a twin frozr II model and because I have to use a 6870 block everything isn't 100% compatible and I can't use my compression fittings. Would it be safe if I filed the pcb down a bit?
What the craziness? Use a spacer, that's the proper method.
Or just something like this
OR
Originally Posted by tsm106 View Post
No dude you just need a spacer. The last picture Karlitos linked.
^^This, I would also get the last one as first preference. Less hassle.
The spacer is also a sleek alternative. But depends on the height you need to clear the PCB.
All better..
The only problem with the slim spacer is not many fittings have enough threads.
Yes, true
@pgimps, pretty sure you have enough information now for you to avoid filling the PCB
1 - 13 of 13 Posts
