1 - 20 of 34 Posts
Thanks for taking your time to take a look-- I appreciate your input!
Need suggestions and opinions for improvement fast-- I'm ready to buy
--Gaming/HTPC
OCZ StealthXStream 600w $49.99 after MIR
Highlights: 80% efficiency, crossfire ready, four 12v rails @ 18amp
G.SKILL PI Black 4GB $44.99
Highlights: 2x2gb, DDR2 SDRAM 800 , Timing 4-4-4-12, cas latency 4
athlon 7750 Kuma 2.7GHz $59.99
Highlights: k10 arch, dual core, 2mb l3 cache, OC 3.2+- potential
BIOSTAR TFORCE TA790GX 128M $109.99
Highlights: 790gx,sb750, pci-e 2.0 (2), pci-e (2), pci (2), onboard gfx, HDMI
SAPPHIRE Radeon HD 4830 512mb $84.99 after $15 MIR
Highlights: Affordable performance <_< what else to say?
Barracuda 7200.12 500gb $59.99
Highlights: 16mb cache, 500gb, 7200 rpm
XIGMATEK Dark Knight-S1283V $39.99
Highlights: Rivals TRUE and Noctua at an affordable price
LITE-ON CD/DVD Burner IDE $23.99
Highlights: Umm..
MX-2 Thermal Compound $5.99
Highlights: Non conductive.. .. No curing time?
--------------------------------------------- $479.38
Where can I cut costs to improve?
Is there anything I should be aware of?
Please input constructive criticism/suggestions/opinions/facts/else
Suggested by you
LG Black SATA dvd/cd burner
$22.99
OCZ Freeze/IC7 over MX-2 thermal paste
WD6401AALS 640GB $79.99
WD6400AAKS 640GB $74.99
Patriot Viper 4GB $18 after MIR
XIGMATEK HDT-S1283
corsair 400w psu
It's not bad, but I think you should replace the Barracuda with this. It's a more impressive hard drive and I trust it more than the Barracuda. Also, what is your budget? If you can squeeze in a few dollars, you can get an improvement in graphics card by buying a Radeon 4850 or 4870.
Also, welcome to OCN. Fill out your system specs so we can use it to better help you later.
Data Recovery Engineer
I think you can put a Phenom II in there, but your on a restriction right? Nice build though i would personally go for a 4850 since you can find one for 144 or so
Also, your MIR will not work most likely....
Reactions: burndollars
Not really cutting costs, but the http://www.newegg.com/Product/Produc...82E16817139004 is a much better power supply that will last for years. Also, I would go with OCZ freeze or IC7 for thermal compound over MX2. They are both much better and are both non-conductive and have no curing time. Good luck!
Now Im fairly new to the latest improvements on componants, but why are you choosing to use IDE when youve got 6 sata ports on the motherboard, especially when the SATA componants are running about the same price.
650w for the same price.
Also a sata burner would be a good idea.
Personally I'd choose a Western Digital 640gb for its gb/dollar and performance.
I've seen better deals for a 4830 but there seems to be none at the moment. I got one for $75.
I'm assuming the budget is $500 give or take?
Wow flood of posts! I can't keep up haha
Thank you all so far --
to answer a couple of things
*Budget is as close to $0 as i can get it
while still maintaining some muscle
*I overlooked the IDE/stata burner scheme! thanks for pointing this out guys
thank you all for your suggestions so far--but keep'em coming
everyone gets rep from me
Well in that case, forget the 4850 and 4870 and definitely buy a SATA DVD drive. I overlooked that too...don't know why.
Oh and don't forget to buy the 640GB Black Caviar drive I suggested a while back. Definitely worth the investment. IMO, the fastest drive you can get for the money.
Efficiencycionado
get the openbox versions and go for a phenom 2 x3 710.
I heard there is something called the Radeon 4700 series coming
hmm...
Originally Posted by kairi_zeroblade
man if you still have some dough to spend try choosing a nice VC other than that..like 4850's or a single 4870..
I was going to do the same thing, but I heard rumors (on this site) that the 48xx series cards 'may' drop price in the next month. So do what Im going to do, im using the 790GX on board and get a premo card when the drop in price and ive got extra $$$
I would have to disagree. Open box items tend to have flaws. One guy on OCN bought an open box item and ended up having newegg screwing him over.
1 - 20 of 34 Posts
