Well guess I went all out , anything missing , any recommendation on piece to change (and forget about the scythe gentle typhoon ap15 they are none left in north america !)
Cpu waterblock
EK-Supreme HF - Acetal Rev 2.0
Gpu waterblock
Danger Den 4870x2 waterblock (w/8 ramsink)
Radiator
TFC Xchanger - High Performance Quad Radiator 480 using a push config
Radiator mount
Universal 120mm Radiator Stand
Fan
4x TFC Triebwerk - Performance Radiator Fan 55mm 1800 rpm 88CFMTFC
Reservoir
FrozenQ FlexTank Multipurpose Reservoir - Black Acetal
Pump
Swiftech MCP 655-01 Water Pump w/ Speed Controller
Tubing
XSPC 7/16 ID 5/8 OD High Flex Tube 1ft
Fitting
1/2" ID Tubing - High Flow Barb - Silver1/2" ID Tubing
3-way Splitter, T Block Crossconnect Adapter
Fill/Drain Port Sealing Plug Silver Shine
Extra
Feser Base - Corrosion Blocker & BiocideFeser Base
KILL COIL 99.9% Pure Silver Wire 0.57mm
And final price 800 $
Cpu waterblock
Gpu waterblock
Radiator
Radiator mount
Fan
Reservoir
Pump
Tubing
Fitting
Extra
