alright guys, last couple questions:
1) coolant = distilled water + zerex anti-freeze/corrosive?
2) how tight should you tighten the spring loaded screws for the waterblock mount? how tite do you tighten the block????
3) dye - non-uv that is, where can i get it
4) is 1/2ID tubing too big? i hope not....
