1 - 18 of 18 Posts
In comparison to the stock one its massive, i just took a closer look at ir and it is sitting linda like it is top heavy, i mite need to tighten the top screws up a notch "this is gonna be aggravating:swearing:" hardly no space to do so,
I also kinda wondered why it didnt come with a small temp wrench for tightening the heatsink bolts down my tool box doesnt have such a tiny wrench.
Discussion Starter · #9 ·
Yes i did follow the instructions, it is was my first time removing a heat sink off a motherboard "I am still in training" and it wasnt that hard the second time around, today i picked up some arctic silver 5 and did the whole scenario again and did it in half the time, that arctic 5 paste is awesome its lowered my temp 3c awesome stuff.
Thanks for all the info on this web site once again i done it the proper way.
Thank You overclockers.
I doubt that finger tight is enough. If you want *you dont have to if you already have good temps* tighten it more with those pointy pliers. Im thinking the close the hs is to the proc the better cooling.
yeah..i have a tt bt also..there great coolers man.. and since you have a intel you should go for more of an increase in your oc...i got from 2.0 to 2.92 on my 3800 c2 which is almost a 50% increase...you went from 3.0 to 3.6 =P ..20%... and its intel so teh ghz'zs are a lot higher..go for at least 4.0 you can make it esay and you'll still be way under 50c's alright well... if you have any questions for icong or about the bgi typhoon just pm me
-trey
You are only supposed to make it finger tight.
And in my opinion finger tight is more than enough unless you are very weak.
Making it more than finger tight isnt going to lessen the temp either.
as long as u dont over tighten the bolts they wont snap, but as for there being no looseness i was told by my boss that when doin up nuts and bolts u should do it up to the point of where it feels solid but not to the point where the bolts r going to snap on u. Also it depends on what diameter the bolts r the smaller the diameter the more chance u have of snappin the bolt. But if it felt like it wouldnt move anywhere when u had them finger tight i would put them back to finger tight, thats just wat i think
1 - 18 of 18 Posts
