Here is what I got so far:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: auto
CPU Clock Ratio ..........................:9
Fine CPU Clock Ratio.....................: 5
CPU Frequency ...........................: 3.8GHz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............:400Mhz
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800mV<<<
PCI Express Clock Drive.................: 900mV<<<
CPU Clock Skew (ps)....................:0 <<<
MCH Clock Skew (ps)...................: 0<<<
DRAM Performance Controlhttp://forums.nonewbs.com/index.php
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 2.0D
Memory Frequency (Mhz) ..............: 800
DRAM Timing Selectable ................: [manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................18
Advanced Timing Control
tRRD...........................................3
tWTR..........................................3
tWR............................................6
tRFC...........................................54
tRTP...........................................3
Command Rate (CMD) ....................:0
Driving Strength Profiles
Driving Strength ............................ AUTO
Channel A
Static tRead Value.........................:11
tRD Phase0 Adjustment...................:<<< Leave for all below as well
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Motherboard Voltage Control
Voltage Type.………... Manual
Load-Line Calibration: Enabled
CPU Vcore….……….........................:1.4
CPU Termination…..... 1.200V*.......: 1.28
CPU PLL…………………....1.500V*.......: 1.5
CPU Referen.…………....0.755V*.......: 0.760<<< .64% Of Vtt (Termination above) Auto ?
MCH/ICH
MCH Core…………….....1.100V...........: 1.3
MCH Reference….…….0.800V...........; <<< Leave (current is set at 0.760v Auto)
MCH/DRAM Ref.…......0.900V...........: <<< auto
ICH I/O……………….....1.550V............: <<< 1.5 auto
ICH Core…………...……1.100V............: <<< auto
DRAM
DRAM Voltage ……....1.800V............: 2.2v (Ram doesn't like running at stock for some reason)
DRAM Termination .…0.900V............: <<< Auto
Channel A Reference 0.900V............: <<< Auto
Channel B Reference 0.900V............: <<< Auto
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled] Enabled if you use Vmware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect ..............[Disabled] *Note* Must be enabled to flash from USB
Update:
Finally got a 3.8 stable in ITB by my temps were really high (76C!!!!):
Clock Chip Control
Channel A
Channel B
MCH/ICH
DRAM
Advanced Settings
Clock Chip Control
Channel A
Channel B
MCH/ICH
DRAM
Advanced Settings
Update:
Clock Chip Control
Channel A
Channel B
MCH/ICH
DRAM
Advanced Settings
