1 - 20 of 27 Posts
I need 4 3/8-18 NPT brass barbs for a potential Wintsch Labs Arctic Web <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> Can anyone find the good ones, with only 1 lip? Similar to the DD high-flow barbs.<br><br>
Thanks <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
well home depot has the ones with about 4 lips on them, ive used them on most of my water cooling rigs of some sort, i guess youve allready thought of that though
<div>Originally Posted by <strong>MADMAX22</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398131#post1398131"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">well home depot has the ones with about 4 lips on them, ive used them on most of my water cooling rigs of some sort, i guess youve allready thought of that though</div>
</td>
</tr></table></div>
See, that's the problem- I need just 1 lip, like these DD ones:<br><br><img alt="" src="http://www.dangerdenstore.com/files/images/misc/fittings/high_flow2_562w.jpg" style="border:0px solid;">
<div>Originally Posted by <strong>Burn</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398119#post1398119"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I need 4 3/8-18 NPT brass barbs for a potential Wintsch Labs Arctic Web <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> Can anyone find the good ones, with only 1 lip? Similar to the DD high-flow barbs.<br><br>
Thanks <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"></div>
</td>
</tr></table></div>
I'm not sure if this is what you want,G-1/8 nickel plated...Let me know, if it's not I will look around some more....<a href="http://www.sharkacomputers.com/niplbafifor1.html" target="_blank">Barbed Fitting For 10mm (3/8") ID Tubing - G1/8 Thread</a>
Discussion Starter #5
Nope- 3/8-18 is the thread spec, not the ID- I should add that I need 1/2" ID barbs.
Here's some plastic ones....I'm still looking for brass ones.<b>EDIT: I cant find any single lip one's just the triples..</b>.<a href="http://www.crazypc.com/products/93451.html" target="_blank">3/8 NPT x 1/2 Barb: CrazyPC Computers</a>
Discussion Starter #8
I could use those, too. I just need <b>metal</b> barbs, not plastic <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
<div>Originally Posted by <strong>Burn</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398203#post1398203"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I could use those, too. I just need <b>metal</b> barbs, not plastic <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"></div>
</td>
</tr></table></div>
So then why not just get the ones from danger den?? maybe I am missing something. lol<br><br><br>
what about these?<br><br>
They have 2 barbs but better them like 4<br><a href="http://www.anver.com/document/vacuum%20components/vacuum%20hose/hose-barbs/a12g12b%21.htm" target="_blank">here</a><br><br>
I think thats 1/2 thread though, I can't seem to find 1/2" barbs with 3/8" threads without them being plastic.
Discussion Starter #10
Wrong thread size- They use G1/4, I need 3/8-18 NPT <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
This what you're looking for?<br><a href="http://www.cooltechnica.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AQX-HIFLO-G38-12" target="_blank">http://www.cooltechnica.com/Merchant...X-HIFLO-G38-12</a>
Discussion Starter #12
Nope- BSPP is the British <b>parallel</b> pipe standard- I need NPT, or national pipe <b>taper</b>. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
<div>Originally Posted by <strong>Burn</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398232#post1398232"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Nope- BSPP is the British <b>parallel</b> pipe standard- I need NPT, or national pipe <b>taper</b>. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"></div>
</td>
</tr></table></div>
I think it might be easier to change what you are trying to fit these in then finding the right barbs.
</td>
</tr></table></div>
It probably is showing that I know next to nothing about pipe fittings/plumbing supplies. <img alt="" class="inlineimg" src="/images/smilies/rolleyes.gif" style="border:0px solid;" title="Roll Eyes (Sarcastic)"><br><br>
I'll keep looking.
Discussion Starter #15
<img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"> I don't expect a whole lot of people to, but for the plumbers out on teh forums, they would know.
Another potential find: <a href="http://www.anver.com/document/pdfs/components/hoses/Hose%20Barb%20Fittings.pdf" target="_blank">http://www.anver.com/document/pdfs/c...20Fittings.pdf</a><br><br>
They are almost definatly beyond your specs, but I think A3812B is what you are looking for. (Or pretty darned close... On second look at the photo, it might be a 2-lip.)
Reactions: Burn
So you need this but in metal<br><br><a href="http://www.svc.com/a6-8np.html" target="_blank">link</a><br><br><img alt="" src="http://us.st11.yimg.com/us.st.yimg.com/I/svcompucycle_1919_44445270" style="border:0px solid;">
Discussion Starter #18
<div>Originally Posted by <strong>atomicfission92</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398251#post1398251"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">So you need this but in metal<br><br><a href="http://www.svc.com/a6-8np.html" target="_blank">link</a><br><br><img alt="" src="http://us.st11.yimg.com/us.st.yimg.com/I/svcompucycle_1919_44445270" style="border:0px solid;"></div>
</td>
</tr></table></div>
Exactly.
Burn I have looked everywhere that I know to look and cant find any..It's getting hard to even find the 9/16 ones anymore everyone's going over to the G-1/4.....If you have a lathe you could just turn off the extra lip's, or even just file them off by hand... I'll keep my eye's open for some but I've just about given up on finding any....
Reactions: Burn
well this sight has some cool info and everyhting else just i couldnt find the oones you wanted in metal but they had some prety interesting plastics and s.s. <br />
<a href="http://www.eldonjames.com/html/fittingfeatures.html" target="_blank">http://www.eldonjames.com/html/fittingfeatures.html</a><br />
<br />
on this page click on the link below the comments pnuemadyne.com then go to the catalog and fittings ..... you get the idea they have some just i dont know the right size, if they ll work, worth a shot and they can also make you what ever you want <br />
<a href="http://www.machinedesign.com/ASP/strArticleID/59029/strSite/MDSite/viewSelectedArticle.asp" target="_blank">http://www.machinedesign.com/ASP/str...tedArticle.asp</a><br />
<br />
anyways a phone call to either one of these places or a email would probably net you what your looking for, i am done looking and i just got a cpu to try out <br />
<br />
good luck
Reactions: Burn
1 - 20 of 27 Posts
