Well, increasing the multiplier by .5 is increasing the CPU speed and it crashing under load is almost certainly caused by a lack of voltage to the CPU.
Overclocking is a trial and error process. You will have to increase the voltage in small increments until it appears stable. This will in turn increase your idle and load temps.
I must also tell you to keep an eye on what the RAM is running at when OC'ing as the RAM frequency usually increases in relation to CPU frequency however I am not very familier with AMD set ups.
