Just looks like it scans prints. You probably want to buy the first one I posted it supports Windows 8. The 2nd one I posted doesn't have software so avoid that one. And the one you posted are only readers and has no support for security. They may not work with Windows 8 because the manufacturer must update the drivers/software. It's probably a safer bet to get the Windows 8 supported one.Originally Posted by JacP3
What about this one? Looks like it should do the job but I want to check before I spend £30 on it...
