1 - 5 of 5 Posts
Just finished my very first build as of a few hours ago. Thank you to those that helped me decide on a cooler. I ended up just being cheap and buying a 40$ corsair h50 from bestbuy. Figured if I wanted to upgrade later I would just return it and move on.
I've been running prime95 for about an hour now on and off. Currently at 4.5ghz with a 1.35 core voltage. I've been averaging about 35c idle temps and full load temps at about 64-70c. I'll continue to prime95 stress it to determine some stability, but do those temperatures sound ok?
Build: cost was about 1200$ after everything
i7-2600k
msi p67a-gd65
evga superclocked gtx 570
8 gig 1600 ripjaw
corsair 750w
corsair h50 cooler
Few pics below also from tonights build. Oh and im aware that the ram isn't dual channel atm. I was having problems booting at first without a few bios tweeks. Its fixed now
Attempt one at wires
Attempt two at wires
gotcha, thanks for the feedback. I have a second fan.......in my lap actually. I'll go ahead and give the push pull a shot. My arctic 5 has also had about 35 minutes of setting in time so far lol. So that might effect things a few degrees.
no complaints as of yet. My ram was a bit finicky at the start, wouldn't boot as dual channel till i changed the frequency and voltage in the bios. Obviously the OC genie is garbage but no surprise there. Seemed to achieve an easy overclock.
I see you have the same one. Your thoughts?
Edit: the bios made me lol pretty hard. Wasn't sure if I was supposed to tear through all of the settings or search for crayons, coloring books, and playdough.
1 - 5 of 5 Posts
