1 - 5 of 5 Posts
Anyone else having problems with 2.0? Its causing my system to intermitently and mysteriously reboot. Interestingly, I did not have this problem with the RC version. Gonna try to reinstall...
No...So far the only thing I dont like about it is that half my favorite extensions dont work with it yet....The last upgrade gave me quite a few problems, had to reinstall 3 or 4 times before it finally setteled down...
I might have tacos tonite
I tried to use it, but couldn't because it refused to use ssl 2.0
Discussion Starter #4
Thanks, I had the same problem with the extensions, but (I think) it cleared up quick.
Discussion Starter #5
Nevermind...my rig just crapped out without Firefox.....
1 - 5 of 5 Posts
