As im sure many of you know the 5850 has a problem with duel monitors where the 2D clocks drop too low and cause flicker if you have overclocked your card. The main fix for this is editing 2D clocks in your catalyst profile.
I have also discovered that flicker can also be cause by firefox causing clocks to jump to max and back down again. This can be fixed by going to options->options->advanced->general in firefox and unticking the "use hardware acceleration when available" box.
Hope this helps some1
