Firing up the Phase!
4840 Views 86 Replies 23 Participants Last post by  CyberDruid
It's counting down! Soon it will be either subzero or a big zero LOL.
1 - 20 of 87 Posts
Awesome man...Check out my H2O build I'm doing as we speak..!!
In my sig..
Good luck buddy!
Big zero so far--I followed the instructions and nothing happened--well the Chilly1 turned on. counted down and then chilled to -23 then went into an idle mode or something--never turned on the pC.
Not sure what to do--so I am waiting for the count down again.
Sure hope I can figure this out.
ooo awesome, can't wait
I hear ya CD..I'm still trying to figure out questions I have about H2O stuff..Since I'm building right now...and am trying to finish by tonight!
Good luck with it, I cant wait to get my phase setup installed and running.Ive already been busy lapping the new northbridge cooler.
Well I am on top of the phase now--it is on at -41C. The problem now is trying to get the ABit board to see the DVD drive so i can load Windows. I have tried everything...I hate stupid stuff like this. All I can think is that the 18X DVD RAM drive is somehow not registering as a CD ROM. No sign of it in BIOS or POST and all I get is a disk read error when I try to load windows...ARRRRGH
Pictures? =D
Hmm...Go through all the obvious stuff, like IDE and power cables hooked up, jumpered properly, make sure your IDE slots are on...Yes, on the DFI boards, you can turn IDE ports on/off
Can you see your IDE ports in the Device manager?
Well I am running an Abit AA8XE that has one IDE and a mess of SATA and I do not see the DVD drive in POST or BIOS--it just does not show.
I dug up an old CD ROM and am about to give it a try now
Worse news...now the board will not start at all..not sure what is going on so i just cleared CMOS and am waiting for the countdown.
I mean nothing--I can bridge the PW SW pins on the header and nada--the board ia ll lit up and the digital display read 0.0 and that's all she wrote...
I sure hope I didn't kill that pretty board.
Wait, did you use AS5 in between the CPU and phase head? Because I herd that can kill stuff, you are suppose to use a non-conductive thermal compound.
What about dielectric grease?
yea iwth phase the AS5 isnt good, you need the ceramique for temps below 0 IIRC
It won't kill stuff, it'll just bleed and separate.
Make sure that no condensation is visible on the board....Anywhere.
He rec'd a fresh tube of ceramique with the chilly1.
Board lights up --will not start. Cleared CMOS twice with the PSU unplugged. Swapped RAM. I dunno.
One thing I did that was pretty stupid was I saw a stored BIOS setting in the load form profiles area of BIOS and I loaded it...it was for 4.5 ghz with the RAM running 1:1. Maybe some other tweaks...I dunno. I would not think that would kill it though. Not sure what I did or what happened. The phase works except that it does not switch the board on so even with a seperate switch nothing. I tried the onboard power and resets--nothing. Nice light and a nice digital readout (0.0) but nothing happens.
Pretty sorry state of affairs and I can only blame myself.
Really a drag.
Really a drag.
4.5? That's most likely that it killed your CPU, woah.
1 - 20 of 87 Posts
