1 - 20 of 388 Posts
AAGGHH~ MY EYES~ AAGGHH~
Different way, needs more testing
this measures how long clicks last. l.exe for left clicks, r.exe for right clicks
https://drive.google.com/file/d/0B5_qzxdnJV0PSTJpLUNITFl6Sk0/view?usp=sharing
(yea you can do it too with the previous thing but this is easier for taking averages)
Open either l.exe or r.exe
Click the mouse button in the fastest/quickest way you can. Different force will be required depending on the mouse.
Keep track of the lowest number you see.
Try and beat that number
When it seems you can't get a lower result, screenshot or copy the numbers in the window.
Post em if you want(Make sure to specify the report rate(1000hz,500hz etc) and which mouse you tested.
Generally the higher the debounce, the harder it will be to get the switch to register with very little force.
There are exceptions to this though.
Let's make believe you are a mail room clerk tasked with coding the firmware for a mouse. In this case the MAD CATZ RAT 1.
See those numbers? The debounce delay is 14ms, but the delay between button presses goes as low as 1.96ms.
Another exception is if the mouse has proper debouncing:
Areson/Gigabyte M63 Raptor:
Any Logitech gaming mouse ever made(G303 in this case):
In those cases, the debounce delay is low but the button release delay is set to a higher value.
...or something, anyway i'll be interested in seeing any results posted
PRETTY EASY.
Alligator Clips?
Software:
Previously Used Methods:
Rafa's Method:
Rafa's infamous graph:
Thunderbringers Method:
Additional tests performed by Thunderbringer:
Originally Posted by Thunderbringer View Post
Some results i got from testing, the Steelseries Ikari Optical always as reference:
CM Storm Alcor (1.2.0 firmware)
Logitech G302
Razer DA 3G (1.35 1.28NDC firmware iirc)
Razer Abyssus 3G
The difference between my and rafa´s Abyssus result is kind of big. Either the response time can vary ~10ms from unit to unit or the Mouse driver plays a role? I plan to test Abyssus with installed driver soon. (Edit: made no difference, still ~12ms with driver installed!)
@OP No BS.
ZowieAM vs SS Ikari Optical (difference: 16.9ms-18.9ms) :
ZowieFk1 vs SS Ikari Optical (difference: 15.9ms-17.9ms) :
I have compared the Razer Viper button latency with a SS Ikari Optical, out of curiosity since the Viper Sensor implementation always felt very responsive to me. (can not provide pics this time, dont have access to my pc/moving atm)
The Ikari
is 35-40ms faster,
haha.
Hoorai GM1100 (A) vs SS Ikari Optical (B)
sousu:
This slower method emulates rafa's method without soldering
I would like to remind you that this method can be done in a variety of ways. There is no one way for it to be done. You can use different connectors, alligator clips, and so on. I only do the jumper method because it's clean and simple.
Materials:
2 mice
Solderless Breadboard
Jumper Wires
Spare microswitch(you can just pull one off a spare side button pcb, it will work just as well)
2 mice, and a omron d2fc7n on a solderless breadboard:
4 jumper wires(In this case male to female)
Wire the jumper wires in a way that has them connected to the CENTER PIN and PIN LOCATED NEAREST TO THE BUTTON ON THE MICROSWITCH In this case there are spaces between the pins, so I only connected the jumpers to the appropriate pins slot.
Connect the wires to the contacts on the underside of the mice being tested. This can be very irritating especially with the shown method. Just make sure they are somewhat secure in the sense that they do not move.
Again, there are so many freaking ways to do this. However in this case, I wired the male part of the jumper cables to raised sockets on the solderless breadboard. One row goes to one mouse, the other row is wired to the other mouse. So now when the switch is pressed on the breadboard, the switch will actuate both switches at the same time.
Alternate shot that I included for reasons I can't recall.
Mice That I Have Tested(More in the thread, but laziness has kept me from updating the OP
M63 Raptor vs Ikari Optical Test Result:
So what would be the fastest mouse I have tested so far? The Gigabyte M63 Raptor.
Out of 700 events, Ikari Optical only won 37 times. So averaging the remaining events the Raptor won....
Average: 0.563411ms
Deviation: 0.541327ms
ikarivsm63raptor.txt 7k .txt file
Mouse that I've tested so far and will might possibly eventually re test so I can have averages for everything. Still the numbers presented are accurate, only now when I redo them they will be higher in general because I will the use Ikari Optical instead.
diamondback 3g
first test:http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24245115
second test:http://www.overclock.net/t/1411332/mouse-button-lag-comparison/550_50#post_24380387
diamondback 3060/3070 http://www.overclock.net/t/1411332/mouse-button-lag-comparison/450_50#post_24349586
diamondback plasma le http://www.overclock.net/t/1411332/mouse-button-lag-comparison/450_50#post_24349586
rog sica http://www.overclock.net/t/1411332/mouse-button-lag-comparison/350_50#post_24230099
deathadder 3g
first test:http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24240641
second test with ideal fw:http://www.overclock.net/t/1411332/mouse-button-lag-comparison/500_50#post_24373151
abyssus 2014 http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24245218
g302:
first test:http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24248785
second test: http://www.overclock.net/t/1411332/mouse-button-lag-comparison/550_50#post_24376166
g303: http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24250938
azio ex01 http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24255810
zowie fk1 2015 revision http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24308673
tt esports talon blu http://www.overclock.net/t/1411332/mouse-button-lag-comparison/500_50#post_24364755
g100s
first test: http://www.overclock.net/t/1411332/mouse-button-lag-comparison/350_50#post_24225565
second test: http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24248785
sensei raw
first test: http://www.overclock.net/t/1411332/mouse-button-lag-comparison/350_50#post_24235781
second test: http://www.overclock.net/t/1411332/mouse-button-lag-comparison/550_50#post_24376297
m63 raptor
first test:http://www.overclock.net/t/1411332/mouse-button-lag-comparison/350_50#post_24229916
second test: http://www.overclock.net/t/1411332/mouse-button-lag-comparison/500_50#post_24368341
team scorpion x luca r http://www.overclock.net/t/1411332/mouse-button-lag-comparison/350_50#post_24235918
copperhead(all firmwares) http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24251911
nova slider x600 http://www.overclock.net/t/1411332/mouse-button-lag-comparison/500_50#post_24357688
alienware tactx http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24294118
razer krait 1600dpi http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24245115
evga x3l http://www.overclock.net/t/1411332/mouse-button-lag-comparison/450_50#post_24357193
creative f2020 laser http://www.overclock.net/t/1568089/old-school-mice-fatal1ty-2020-laser-mouse-pics-feels-debounce-delay-test/0_50#post_24260187
ikari laser WOOPS NEVER POSTED IT
ikari optical POSTED IN THIS THREAD
lachesis 3g http://www.overclock.net/t/1411332/mouse-button-lag-comparison/400_50#post_24278133
roccat lua http://www.overclock.net/t/1411332/mouse-button-lag-comparison/450_50#post_24348971
All Logitech, Razer & Steelseries Mice Tested So Far:
Logitech:
G1
G100
G100S
G3 LASER
G3 OPTICAL
G5 LASER
G300/G300s
G302
G303
G400
G400S
G402
G502
G500
G600
G9
G9X
MX310
MX518
Razer:
Viper
Lachesis 3G
Salmosa
Copperhead
Krait
Diamondback OG
Diamondback Plasma LE
Boomslang 2007 CE
DeathAdder 3G
Deathadder Chroma
Deathadder 3.5G
Habu
Spectre
Abyssus 1st Rev(Unclear)
Abyssus 2nd Rev(Unclear)
Abyssus 2014
Taipan
Steelseries:
Ikari Optical
Ikari Laser
Kinzu V1
Kinzu V2
Kana
Kana V2
Sensei Raw
Rival
Reaper Edge
Kana
Xai
Missing/Untested Logitech, Razer & Steelseries Mice:
Logitech:
MX300
Razer:
Lachesis V2 5600dpi
Mamba
Mamba 2012
Mamba Tournament Edition
Naga* & Naga 2014
Orochi
Imperator & Imperator 2012
Tron
*Multiple versions released, differences unknown.
Steelseries:
Kinzu V3
Sensei A9800
Sensei Fnatic A9500
World Of Warcraft mmo
lololol
you can skip the breadboard and just connect each mice's switch, and just click one of the switches to actuate both
Yeah was too paranoid to do it.
Anyone have a G1 laying around? It is the only g series logitech mouse that has not been tested.
lololol
there's also the g300s you're missing
lol alligator clips...totally forgot about those. that makes this test completely trivial now
Discussion Starter · #9 ·
Fixed. Forgot it existed somehow. G300s was just a new shell, so I'll put it with the G300 as tested.
Maybe include a ninja technique on how to remove the feet without ruining them. Hopefully this thread will take off with more contributors.
Discussion Starter · #11 ·
Yeah, not a lot of people out there willing to puncture/drill holes in the mouse feet and and not replace the feet afterwards.
Though in my first g303 it added some drag which I got used to, then had to readjust when I got a new one.
sorry, could you please explain the method textually? I miss the guide
connect both mice
connct Mouse 1 MB1 pin [middle] to Mouse 2 MB2 pin [middle]
which button to press? MB1 / MB2
possible programm putput is - and +?
What is the exactly difference to the other methods?
Analyzing Firmware Added Mouse Button Delay
Real analyzing? I don't get it. Your are also measuring the delay, didn't you?
Sorry if I misunderstood the whole thing....
connect both mice
I was confused too. Which is why I didn't post in this thread.
Discussion Starter · #15 ·
1 wire. Connect the middle pin on the switch contact (underside of the pcb). Wire both mice together like shown in the op. Hit either switch to actuate both.
lololol
negative means the left button registered first.
positive means the right
it's explained in the readme...
Discussion Starter · #17 ·
Originally Posted by uaokkkkkkkk View Post
Good so I won't have to buy the kinzu v1 now. Fine by me.
- = Ikari Optical
+ =Sensei Raw (fw120)
300 Events
Winner: Ikari
Average:6.90485ms
Deviation: 1.11221ms
sensei.txt 3k .txt file
Steelseries Xai. Sensei with a lcd screen basically right? Well about that...
Method Used:
Yeah, yeah I know. But I enjoy it this way more for some reason.
Steelseries Xai fw1.2.179
Winner: Ikari Optical
Events:300
Avg : 10.8152ms
Deviation. : 0.834344ms
Max. : 12.8776ms
Min. : 8.86943ms
xai12179.txt 3k .txt file
Absolutely pitiful.
However! You can't use this firmware with any of the available software, so this would be filed under unusable.
So here is the one I found useable.
Steelseries Xai fw1.3.1
Events:300
Avg: 5.32837ms
Deviation: 0.618615ms
Max.: 6.87515ms
Min: 3.8698ms
131fw.txt 3k .txt file
Much better. So faster then the Sensei Raw with the proper firmware. It's not Ikari fast but that was never expected. Oh, and 1.4.2 has the same fw debounce delay as 1.3.1
Slapped a sensei raw shell on to reduce the weight even more after removing the side button pcb. Xai shell is definitely sturdier though.
Oh and this is all I did to maintain glide this time:
Another steelseries mouse to cross of the untested list.
lololol
we've gotta figure out a setup for you to do a 2015 version of mousescore to compare variance between all those mice
Debounce affects scrolls the same way as switches?
Sucks that each firmware update would have to be tested because sometimes they feel like changing the debounce for no reason. That's what happened to the Ninox mouse -- the factory added a bunch of debounce for "improved quality."
lololol
for optical encoders probably nonissue with a bit of hysteresis.
for mechanical encoders...
on my ninox aurora i'd always get "scrolling neg accel" when scrolling fast. checked with mousetester interval plot and turns out you cant scroll faster than like one scroll/5ms
on my torq x5 there's no such issue. just checked again... it's like 2ms when i use my forearm to spin the wheel very very quickly. on optical encoders i can easily get down to 1ms, so that means there's a 2ms debounce time or something with the torq x5
1 - 20 of 388 Posts
