1 - 7 of 7 Posts
It's the worst of the bigadv but still nets decent PPD. You should see around ~18k or so with it and a point dump of probably 61-62k when it's finished. Could be a little either way but that should be a good ballpark for you. Congrats on getting and and enjoy.
PPD greatly depends on many things.
Your 3.8ghz already makes it less than the average bigadv folder having 4.0ghz.
Also you have ATI cards that put more of a strain on your CPU if your folding them as well.
Just wait about 3 hours and you should get your PPD value, if your using your PC its also going to lower it just a bit.
Originally Posted by Rud3Bwoy
when you gold bigadvs it gives you points even before it finishes?
No
Originally Posted by CovertCover
Anyway, yeah I'm getting 18-19k...and even if it is a bad -bigadv o well haha
Not bad
Hey
I just got WU 2684, which I believe is a -bigadv WU, which means...IT'S MY FIRST -BIGADV WU!!!
Anyway, anyone know anything about the PPD of this WU?
Thanks
At that clock speed, if you aren't running much else that is taking any CPU resources, then you should get about 60-65k points from that WU, and it will take about 3 days.
If you get one of the better bigadv WUs, at the clock speed it will take closer to two days, but give you the same amount of points.
I've found that even the worst bigadv WUs give me about 5k PPD more than standard SMP WUs.
1 - 7 of 7 Posts
