The story so far:
This is a budget office-work build for my parents discussed here and here. The specs are my current sig-rig.
The plan was this: install the Celeron D 331, update the BIOS (to support the E2140), remove the Celeron, install the E2140, install XP, win.
Heres what actually happened: I installed the Celeron, both 512MB sticks of RAM, the CD/DVD drive, the HDD and FDD. I connected the screen, keyboard and mouse and booted up. 1 beep, it boots first time with no errors, success! Not wasting any time, I hit DEL and enter BIOS straight away. I already had a floppy with the F2 BIOS following the instructions for Q-Flash. I inserted the floppy, pressed F8 to bring up the Q-Flash menu and proceeded to flash the BIOS. All the checks were fine and the BIOS flashed successfully (a message confirmed this). After this, I powered down through BIOS and restarted; 1 long beep and 2 short which the manual lists as a "Monitor or display card error" confirmed by the lack of input detected by the screen. The HSF fan starts and the HDD hums and I can open the optical drive but the screen doesn't detect anything.
To re-iterate, I changed nothing after flashing the BIOS so I know for sure that the hardware is working and I am absolutely sure that the BIOS was the correct version as confirmed by the "successful" flash. I have since tried reseting CMOS by removing the battery for 2 minutes to no effect.
Any ideas what could be going wrong? I can only guess that somehow something went wrong in the flashing process, but the success messages contradict this. Help would be very much appreciated.
