1 - 8 of 8 Posts
Ok so I finally got my computer up and running but have found 3 problems.
1) My screen isn't full size, it has a black border. FIXED
2) I have my ethernet cable connected but I have no internet. FIXED
3) My 2nd SSD isn't showing up. FIXED
Please help me with these problems!
Thanks!
Have you tried to use the "auto" or "auto-adjust" button on your monitor? this might fix the black border problem, i often have the same problem while switching back and forth between my server and gaming pc trough my kvm switch.
Discussion Starter · #6 ·
Ok I got the internet issue fixed (I had to install the driver off the motherboards disk).
And no I haven't installed the GPU driver.
Ok 2 of my problems are fixed.
My internet is working and I have no black borders around my screen anymore.
How do i make my 2nd SSD available? When I right click on my computer and go manage, I then go to Disk Management and Disk 1 says Unallocated.
How do I make it allocated?
Thanks!
1 - 8 of 8 Posts
