First build need help and or opinions
433 7
Ok so this is the first time I have ever built my own computer, so I am not exactly sure about all these parts and their compatibility with each other.
my budget is about $1,400 but I'd like to keep it at about $1,375 or so at the most, but anyways here is my build so far.
Case:
XCLIO WTBK ADVANCED ( I have heard this case has some problems with the fans and wires/LED's but i want it for the airflow)
Hard Drive:
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s
External HD:
Maxtor OneTouch 4 Mini STM902503OTA3E1-RK 250GB (just for storage)
Power Supply:
SILVERSTONE ST75F 750W
CPU:
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz
Motherboard:
EVGA 132-CK-NF78-TR LGA 775 NVIDIA nForce 780i SLI ATX
RAM:
Kingston HyperX 4GB 240-Pin DDR2 SDRAM DDR2 1066
CPU Fan/Heatsink:
XIGMATEK Dark Knight-S1283V
GPU:
EVGA 512-P3-N884-AR GeForce 9800 GTX+ Superclocked Edition
Disc Drive:
SAMSUNG Black 22X 2MB Cache SATA DVD Burner
OS:
haven't decided if I should go with Vista or 64 bit XP
My main goal is to be able to play GTA 4 decently enough to enjoy it, I also plan to OC the CPU at a later date. Since this is my first build I just wanted to make sure everything would work together.
Thanks in advance for any help or opinions
1 - 8 of 8 Posts
STG3 VET
Looks OK to me. I would swap the mobo for a decent P45 board (Giga UD3P) unless you really plan to go SLI in the future. (even then, with the rumored ATI price drops, the 48xx's look good. Also, I am not a big fan of Xckio, but to each their own and it is only a case, not a PSU or something)
I would get Vista 64 (Home Premium or Ultimate) Don't mess with XP x64. yes, you can get almost eveything to work, but there is no benefit to an older OS if you don't already have it)
You can get a way cheaper PSU that will run your rig just fine. Which would possibly save you around 40$ in just that area. Maybe consider going i7/DDR3?(not worth it imo but if you have the money wth right?) With the 40$ that you're saving on the psu, get a 260 core 216 or a 4870 1gb.(I personally would prefer a 260 but that's me :/) Idk the pricing on that hard drive either, but I DO know that Seagate has a Barracuda at 69$ for 640gb. worth the price imo.
(Same amount of cache)
As far as the case goes: It's really whichever you think looks the best. If you like the xclio looks then go with that. But there are better cases with airflow. Such as the Antec 900/300. Coolermaster 690 has spectacular airflow. Just doesn't have a side window.(Although you can purchase one for about 20$) That's my
Discussion Starter · #6 ·
ok this is what I'm looking at now
Case:
XCLIO WTBK ADVANCED
Hard Drive:
Seagate ST3640323AS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s
External HD:
Power Supply:
CORSAIR CMPSU-750TX 750W
CPU:
Motherboard:
RAM:
CPU Fan/Heatsink:
GPU:
EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB
Disc Drive:
LITE-ON Black 22X DVD Burner
OS:
Vista Home Premium SP1
price tag $1,348.52 ( after shipping)
Discussion Starter · #8 ·
Originally Posted by Tinh Ngo
with your price that your speding 1400$ i would go with i7
I Cant find a way to get the motherboard and an i7 with DDR3 for about the same price at newegg though.
It's always like $150 more...
1 - 8 of 8 Posts
