1 - 12 of 12 Posts
Ok so i am going to be making a custom case soon. I have never done this before and i really hope that it turned out as good as i picture it. I am wondering what you guys think is the best way to cut out 120MM fan holes into an older tall tower made from metal. I am also going to be putting in a custom acrylic side panel and doing a black paint job (inside and out of the case) with a painted white design on the acrylic window. I would love the design on the window to be uv reactive. Do you guys have any suggestions on the type of paint i should use for the primer, black and uv reactive coats? (if you can even do the uv reactive part haha) I am going to be putting 2-4 light bars in the case and at least 4 120MM green led fans in the case.
Programmer
look at other peoples case mods on overclock.net. you will get the best ideas going around to supe up ya case.
You can pick up a great little Hole Saw attachment for a drill at your local home depot. If you have a corded drill - or a higher powered cordless one - it cuts through with a nearly perfect hole pretty quick. 4" - 4 1/4" (depending on how much overhang you want) will be perfect for a 120mm fan.
Link to The One I Have
Yeah - I have a little Black & Decker 7 volt drill and it cut through the plastic bezel no problem...but it was just too weak to make it through the actual case metal. I borrowed my buddies 18v one and it sliced through no problem.
Programmer
nice tuk case mod clbkdaz. hey do you remeber me? the guy who asked about the coolers. i decided to get the nv120 premium. can you remeber me, ive changed my display pic tho lol.
Of course...you were having trouble getting your Q6600 stable...
awesome. I am now looking for a good tall tower for cheap. The one i was planning on using won't hold my cpu cooler (not deep enough )
Well - It's not neccesarily tall you need, rather than deep. Antec Performance series cases, Cosmos, Lian's, and plenty others are out there.
1 - 12 of 12 Posts
